LT1 PBR ?'s
Old Mar 31, 2012 | 10:03 AM
reride's Avatar
Car: 1989 IROC-Z Convertible
Engine: 5.7 TPI
Axle/Gears: 3:23 Posi w/ alum. driveshaft
LT1 PBR ?'s
I have just swapped a '94 Z28 rear in my '89. When I checked out an exploded view of the calipers so that I could rebuild them I noticed a small metal that went between the pads. The calipers on my rear didn't have these and there was some silicone on the back of pads between them and the pistons.
My questions are...are these metal pieces nessasary? And how good (and safe) is it to use silicone to hold the pads in place? I think I already know the answer to this one.
Old Mar 31, 2012 | 08:18 PM
88RS's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: lt1 10 bolt 3.23
Re: LT1 PBR ?'s
are you talking about pad shims?
Old Apr 3, 2012 | 02:49 PM
reride's Avatar
Engine: 5.7 TPI
Re: LT1 PBR ?'s
I'm don't know what they are called, they are H shaped and look to be very thin. Thanks, Steve
Old Apr 3, 2012 | 03:24 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: LT1 PBR ?'s
Those go in the top of the caliper above the spring wire on the pad. I guess it keeps the harder spring wire material from wearing into the aluminum caliper.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
///DAN///
Sep 25, 2015 02:15 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
