Brake light coming on after pv install
Old May 14, 2012 | 07:19 PM
Dskeezy16's Avatar
Car: 1985 Firebird Trans Am
Engine: ls1
Transmission: t56
Axle/Gears: 8.8 Ford 3:73's
So I just finished installing a adjustable summit pv and now whenever I step on the brakes I get the ebrake light flashing in my face. I bleed the breaks with the pressure all the way up and it was just trickling out the rears just like it did before the new pv. My brake pedal would travel about halfway down and then be solid when I was bleeding, it never went to the floor except for when the fronts were bleeding. I have the j65 brakes. I think there mite be something blocking the lines to rear what do you guys think?
Old May 14, 2012 | 08:06 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Brake light coming on after pv install
It could be the hose section in the back, I had them fill up with rust and debris before.
Old May 15, 2012 | 07:54 AM
84ws6ta's Avatar
Car: 1984 Trans Am
Transmission: JW Performance 700R4
Axle/Gears: Borg Warner 9-bolt, 3.08 gears
I don't know how many miles you have on this car, but changing the brake hoses would be a good idea. Steel brake lines generally rust from the inside out and the inside diameter of the brakes lines in the rear are much smaller than up front. As Edwardgp said they can fill up with rust/debris. I would also replace the bleeder screws if you haven't already, as they can rust up and block flow when bleeding the system. The other question is how are you bleeding them? Do you have another person opening and closing the bleeder screw when you push on the pedal? Or are you using a one of those one man brake bleeder kits? The kits generally don't work well because you can still suck air in past the threads on the bleeder screws when releasing the pedal unless you've sealed them.
Old May 15, 2012 | 04:46 PM
Dskeezy16's Avatar
Engine: ls1
Transmission: t56
The car has 96000 on it. I know it sat for atleast ten years before i started driving it. I have my brother opening and closing the screws while im in the car
Old May 16, 2012 | 07:11 AM
84ws6ta's Avatar
Car: 1984 Trans Am
I would change the brake hoses all the way around and inspect the brake lines themselves. Brake fluid absorbs moisture and sitting there for tens years, you may have some issues with rotting brake lines. My friend has a '75 442 and his rear lines rusted through after sitting for 7 years. The other issue is debris can work their way to the piston seals and can cause them to leak.
Old May 16, 2012 | 06:25 PM
Edwardgp's Avatar
Engine: 454-350
Dskeezy don't forget to let us know what you find we might be able to help you some more.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
