drum brake issues
Old May 19, 2012 | 04:51 PM
budfreak1's Avatar
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
drum brake issues
My gta doesnt want to stop the rear wheels from spinning when idling up in the air unless i mash the pedal as hard as i can. I adjusted them and no change. Do they have an auto adjuster? If so, could it be installed backwards? Sorry, but i've always been a disc brake guy.
Old May 19, 2012 | 05:25 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: drum brake issues
Yes they are auto adjusted, I would be looking at the rubber hose section for the back brakes. They will plug up with rust and debris over time.
Old May 20, 2012 | 10:08 AM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
I will check that out. I took it for a drive last night and the brakes seem to be better even though it still acts the same in the air, but now I suddenly have a vibration under braking. Might just tear the drums off today and check things out.
Old May 20, 2012 | 03:08 PM
Edwardgp's Avatar
Engine: 454-350
Just came in from the shop been working on my ride. Look around really close after pulling the drums and if you take it apart leave one side together for reference.
Old May 21, 2012 | 08:21 AM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
Well it looks like it fixed itself. The brakes are definitely working better since I adjusted them and the vibration wasn't there when I went out yesterday for another test drive before tearing anything apart. Not broke, don't fix it lol.
Old May 21, 2012 | 05:59 PM
Edwardgp's Avatar
Engine: 454-350
All right what has probably happened is your self adjusters at the bottom of the backing plate between the brake shoes need to be taken apart and cleaned and lubed.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
