drum to disc swap
Old Jun 7, 2012 | 07:35 PM
leohaus's Avatar
drum to disc swap
i have a drum brake rear end car(85) and bought a disc brake rear end for gta(87). my question is do i need to get a porportioning valve or can i just bolt it in?
Old Jun 7, 2012 | 07:44 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: drum to disc swap
If you read the Stickies at the top of this Brake forum &/or use the Search feature here on TGO (the little text window at the top) you find the answers that you seek have already been posted many times.
It would take anyone longer to type it out for you here that it would take for you to read it where it has already been posted.
Old Jun 21, 2012 | 03:49 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Some have had no problem without swapping prop valve but most prefer to swap it or use an adjustable valve. A search will give details on both. If you swap make sure to get the right one for your car as there was three different disc/disc prop valves due to line and thread sizes.
Old Jun 28, 2012 | 03:47 PM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
I say go to an adj valve. I did and the brake feel is now really good!
Old Aug 4, 2012 | 07:52 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
So where the stickies for the drum to disc swap?
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
