porportioning valve
Old Jun 11, 2012 | 04:19 PM
irocdls1's Avatar
Car: 88 Iroc ls1 swap
Engine: ls1
Transmission: 4l60e
Axle/Gears: original disc
porportioning valve
I need a proportioning valve for a 10 bolt haven't been able to find one but i found one for a 9 bolt I'm assuming that they are the same ... does any one know if this would work the same .
Old Jun 11, 2012 | 05:49 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: porportioning valve
Bolt up. Use a drum valve for drums, a disc valve for discs.
JamesC
Old Jun 12, 2012 | 11:04 PM
irocdls1's Avatar
Engine: ls1
Transmission: 4l60e
so it will work then thanks alot didnt want to change it then find out that it wouldnt work.....thanks again
Old Jun 13, 2012 | 06:13 AM
JamesC's Avatar
Info concerning valves below that you should probably peruse:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
