LS1 booster and MC help.
Old Jun 14, 2012 | 09:04 AM
Grifter757's Avatar
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
I'm thinking of switching to a LS1 Booster and MC. I tried to but haven't come any REAL answer as to what i need to change. Also hear problems with "spongy" feel. What can i do to fix this now? FWIW I'm doing this cause the LS1 booster sits closer to the firewall and I'm trying to make more room in the engine bay. Also would a LT1 booster work as well? I have a complete LT1 Booster and MC. Thanks for the help.
Old Jun 15, 2012 | 07:45 AM
Grifter757's Avatar
Car: 87 IROC,
Transmission: 4L80E
Re: LS1 booster and MC help.
Nobody has run a 4th gen booster?????
Old Jun 15, 2012 | 01:15 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Would like to know this too. Is the LS1 unit adjustable?
Old Jun 15, 2012 | 01:39 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
How much closer is the LS booster really??
I can't imagin its more than a 1/2".. Maybe it is
I hav seen a bunch of them swapped but I really don't know if its worth it other than saying you did it.
Old Jun 19, 2012 | 10:17 AM
Grifter757's Avatar
Car: 87 IROC,
Transmission: 4L80E
1/2" is about what i need. Need to replace it anyway. Wish i could get some more insight.
Old Jun 26, 2012 | 11:54 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I'm running a 4thgen booster and master...
Old Jun 26, 2012 | 11:59 PM
FueledSoul's Avatar
I posted this before but I'll post it again
You can see the LT1/LS1 are smaller in length. The LT1 and LS1 master are the same only thing that is different is the reservoirs and one fitting size on one line... the Ls1 is a direct bolt in the LT1 you need a adapter to correct one of the line sizes...
FueledSoul's Avatar
First pic: 4thgen booster on your left, 3rdgen booster on your right
Length comparison as if they where mounted on the firewall...
Old Jun 27, 2012 | 12:00 AM
FueledSoul's Avatar
LS1 master/ 3rdgen disc disc prop valve...
I had cut the rear support bracket off...
Old Jun 27, 2012 | 12:02 AM
FueledSoul's Avatar
Here's the brake switch that i had to set back to correct the rod length issue... Just jam nutted it in place
Old Jun 27, 2012 | 12:13 AM
FueledSoul's Avatar
3rdgen booster and master...
4thgen LT1 booster and LS1 master
Old Jun 27, 2012 | 12:14 AM
FueledSoul's Avatar
double post
Old Jun 27, 2012 | 08:17 AM
TTOP350's Avatar
Outstanding work,Thank you for the pix.
Old Jun 27, 2012 | 09:33 AM
Wow awesome. I'm assuming LS1 weighs slightly less perhaps? Probably so minimal it's not worth weighing. This looks like it takes up less space under the hood which is always a good thing!
Old Jun 27, 2012 | 10:07 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Definately interested in this but i may go hydroboost to get ultimate performance from my big cam. Very little vacuum
I assume performance is similar to thirdgen booster even tho the bore size in the master is different?
Old Jun 27, 2012 | 12:39 PM
FueledSoul's Avatar
Welcome
Where talking ounces if even pounds... the ls1 master is a tad lighter and the boosters are about the same, there boosters... so yeah not even worth weighing lol... the 4thgen stuff takes up less space and also looks nicer especially the 4thgen booster, its much smoother.
I was looking into hydroboost as well since i will eventually swap in a different motor and a cam that is borderline with the amount of vacuum needed for the booster... you shouldn't have a problem running a radical cam if you use a vacuum reservoir or a electric vacuum pump... but hydroboost is the way to go, your brakes feel and operate the same regardless of engine speed...
3rdgen and 4thgen brake booster are both dual diaphragm uints so in the nut shell performance wise they are the same but the master is a different story, i pulled this off of another site
"Hydraulic principals are fairly simple and function on pressure which is force per unit of area, so the smaller the bore master cylinder, the higher the pressure output for a given input force. The inverse is true as well, so the larger the bore master cylinder, the lower the pressure output for a given input force. When evaluating master cylinders for a given application, you're choosing a balance between pressure and volume because the two are inversely related. As you decrease the MC bore size, you increase the pressure output but decrease the volume output proportionally. Additionally, pedal travel increases as well when you decrease the MC bore size since the volume requirements haven't changed, so you need to design for a certain volume requirement with your pedal ratio and packaging constraints since pedal travel and MC stroke length can both be limiting factors if you go too small on the MC bore size."
Old Jul 3, 2012 | 07:11 AM
Grifter757's Avatar
Car: 87 IROC,
Transmission: 4L80E
THanks! THis helps out alot!
Old Jul 4, 2012 | 11:51 PM
FueledSoul's Avatar
Your welcome
Old Dec 18, 2012 | 09:40 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
So I finished polishing my fourth gen master cylinder and have my fourth gen brake booster, is this going to be a straight forward swap? No extra cutting or brackets to make? No holes to drill, enlarge or elongate or slot?
Old Dec 18, 2012 | 09:57 PM
Tibo's Avatar
Car: 1991 Z28 Vert
New polished master cylinder and polished bracket for clutch fluid mount up fine to the thirdgen brake booster. I'll be "upgrading" to the fourth gen if it's exactly like replacing the original.
Attached Thumbnails LS1 booster and MC help.-master-cylinder-1.jpg   LS1 booster and MC help.-master-cylinder-2.jpg
Old Dec 23, 2012 | 05:36 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
FueledSoul, in post 11 you said you used an LT1 master and LS booster. why did you use this combo vs a LS/LS? the LT reqs an adapter to correct a line size.
thanx for the info, now i have another project!!!
Old Dec 23, 2012 | 06:56 PM
FueledSoul's Avatar
You would be right with the lt1 master.Read it again im running a lt1 booster and ls1 master
Old Dec 23, 2012 | 09:35 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
thanx for the correction.
Old Feb 7, 2013 | 01:51 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Two of the auto parts stores that I have checked have the same part number for all fourth gen power brake boosters. Is there a difference in LT vs LS brake booster? If so what part numbers or where did you get yours?
Old Feb 11, 2013 | 02:43 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Fwiw.
On my 00 camaro ss i daily drove a 500rw 11:1 245/248 .620/.630 110 cam
And had zero braking issues regarding vacuum. Or braking distance,pedal feel,etc.
Does it affect stock 3rd gens braking systems with big cams.
Im gonna be upgrading my to 00 booster anyway.
Old Feb 26, 2013 | 10:18 AM
Tibo's Avatar
Car: 1991 Z28 Vert
I am still toying with swapping my thirdgen brake booster for a fourth gen booster. According to Autozone the fourthgen power brake booster is the same for LT1 and LS1.
LS1: http://www.autozone.com/autozone/par...6_131640_7889_
LT1: http://www.autozone.com/autozone/par...mString=search
Thirdgen brake booster only has one part number: http://www.autozone.com/autozone/par...5_131640_7889_
I ordered the fourthgen brake booster and am puzzled as it "appears" to be the exact same dimensions lengthwise. I measured the old one front to back on the car and it is the same as the fourthgen????
So now I am really wanting to know where FueledSoul got that booster, Junk yard, dealer part, National auto parts chain etc.?
Old Feb 27, 2013 | 04:32 PM
FueledSoul's Avatar
They probably keyed in or sent you the wrong one, its a auto parts store.
Old Feb 27, 2013 | 04:33 PM
FueledSoul's Avatar
I got mine right off a 4thgen i parted out
Old Mar 27, 2013 | 12:29 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
The real question is it worth it I have a ls1 master and I'm doing a ls1 brake swap. Do u feel a difference
Old Mar 30, 2013 | 12:37 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Not sure if there would be a difference. I am changing mine out now. I have a manual transmission so it is very tedious work removing the four bolts on the driver's side interior firewall. Maybe an hour just to remove four bolts....
Old Mar 30, 2013 | 11:56 PM
Sojer's Avatar
Let me know I have a free one I got most of my swap free I have a second swap that I will be selling
Old Aug 25, 2014 | 01:56 AM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
I want to just switch the master cylinder with one from a 4th gen. I understand I have to tweak the lines a little but is there anything else I need to do?
Old Aug 25, 2014 | 09:55 AM
Tibo's Avatar
Car: 1991 Z28 Vert
No, bolts right up. But I would change the booster at the same time since you are already four bolts away from replacing a 22+ year old piece.
Old Aug 26, 2014 | 12:48 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Ido have the master cylinder and booster from the fourth gen. Is there a link to a thread that explains the step by step procedure? Or is it simply just changing them out?
Old Aug 26, 2014 | 02:49 PM
Tibo's Avatar
Car: 1991 Z28 Vert
It's pretty straightforward, unbolt the old and bolt in the new. If you need more explaining as to how to replace a master and booster you'll need to purchase a Haynes or Chilton manual.
Old Aug 26, 2014 | 03:22 PM
tonys91rs's Avatar
Car: 91 Camaro RS
I just want to make sure I don't need to bench bleed the unit before install. Thanks
Old Aug 26, 2014 | 05:17 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Any time you disconnect the master cylinder from the lines you should bench bleed it. It only takes a few drops of air to displace fluid to cause you to bench bleed.
Old Apr 17, 2016 | 08:10 AM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
I'm replacing the brake power booster in my 1988 IROC with one from a '98 Camaro.
It's a right hand drive car and I need to move the master cylinder back for clearance from the strut mount.
Found the 4th gen booster is about 2cm slimmer. The studs into the master cylinder are exactly the same size, although the studs thru the firewall are a size smaller.
Old Feb 12, 2017 | 03:41 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Great (but old) thread.
For those that swapped in an LS1 bootser, how much did it raise the brake pedal? Just a rough estimate, the rod looks to be about 3/16" longer (the part that protrudes inside thru the firewall). I would imagine 3/16" at the rod would equal at least 1/2" or more at the pedal.
Old Mar 22, 2017 | 08:49 PM
Chase_Crew91's Avatar
Car: 1991 Camaro RS (WS6/Iroc Clone)
Engine: 5.3 LSX
Axle/Gears: 3:73 Richmond
Has anyone doing the LS1 Booster and Master swap had an issue with hood clearance? I have everything mocked up on my car right now and I am fairly certain after everything is torqued down the master cylinder is going to be sitting up higher than the hood.
Original Brakes and motor
Ls1 Brake Booster, Master Cylinder, 3rd gen prop valve
Old Mar 22, 2017 | 09:03 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Are you sure it's mounted correctly? It looks like it's sitting no at an angle.
Old Mar 24, 2017 | 04:37 PM
  #42
Engine: 5.3 LSX
I dont know how one would mount this incorrectly. It has 4 studs that slide right into the firewall. It isnt fully torqued down on the 4 bolts in the back yet, but even when i push it down as far as it goes it seems high. I am gonna play with it tonight and see if i can figure out the issue. I looks to me as if the LS1 booster has an angled mount on it compared to a flat mount of the third gen.... we shall see, might have to exchange for a third gen
Old Mar 24, 2017 | 05:35 PM
  #43
tonys91rs's Avatar
Car: 91 Camaro RS
I went with my stock booster and didn't have any issues at all. I had to tweet the kind a bit but that's all
thejimsterz28
Sep 30, 2015 08:52 PM
dusterbd
Sep 29, 2015 08:40 AM
