How far back will they fit??
Old Jul 2, 2012 | 04:10 PM
overdriv's Avatar
I have a front set of disc brakes for a 1987 Camaro, rotors, calipers, bearings, backing plates and even the stock spindles.
I know the spindles won't work, but will these parts work for a friend that has a 1966 Chevelle with drums on the front. I know he will have to change spindles, but this stuff looks the same on a lot of GM cars.
Old Jul 2, 2012 | 05:04 PM
irocarter's Avatar
Car: 89 iroc
Engine: 5.7 trick flow heads t-ram
Transmission: wct5
Re: How far back will they fit??
no. 70-81 fbody is a closer fit but you have to have a machine shop drill out the upper balljoint on the spindle to work with the 66 a-arm. even then it's a b#tch to get the alignment correct.
Old Jul 2, 2012 | 05:30 PM
overdriv's Avatar
Yeah, I know the spindles won't work from the F-body, but spindles from the monte's and chevelles ought to fit the 66??? The rest of the parts is the same right?
Old Jul 3, 2012 | 04:00 PM
irocarter's Avatar
Car: 89 iroc
Transmission: wct5
no.
Jeremys87
Jul 14, 2022 09:08 PM
sailtexas186548
Jan 19, 2016 12:21 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
