disc upgrade question
Old Jul 9, 2012 | 10:12 AM
pimpimusmaximus's Avatar
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
I am upgrading my '84 open drum rear end with a '95 posi disc rear end from a Z28. I think that the lines will match up. My question is do I swap my distribution block to an all disc block or do I just use a proportion valve for the rear lines to adjust the pressure. And what dist block to use ('84 4 wheel disc or '95 4 wheel disc?
Old Jul 12, 2012 | 06:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: disc upgrade question
Originally Posted by pimpimusmaximus
I am upgrading my '84 open drum rear end with a '95 posi disc rear end from a Z28. My question is do I swap my distribution block to an all disc block or do I just use a proportion valve for the rear lines to adjust the pressure. And what dist block to use ('84 4 wheel disc or '95 4 wheel disc?
You can use an adjustable valve for the rears. The first-design 1LE valve would also work, providing that your 84 has metric threads. My guess is that you have the old-style cast iron valve, which has SAE threads, vs the newer alum-style which has metric threads.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Jan 19, 2016 12:21 PM
gta90
Sep 15, 2015 04:00 PM
zayne0
Aug 24, 2015 07:22 PM
redmaroz
Aug 16, 2015 11:40 PM
