Rear disk swap
Car: 1987 Camaro
Engine: 355
Rear disk swap
Hey, I know there's a ton of posts on rear drum to disk swaps, I can't seem to find what I need though. At a swap meet, I ran into a guy that had Camaro parts. For $60 I couldn't pass up two perfect condition grid tail lights, posi unit (Auburn I think, not worried about that yet,) and the brake stuff shown below. I can't remember, but I think he said the stuff came from a 89 or 90 Iroc-Z. I'm wondering what other parts I'll need to swap these into my 87 with drum brakes. Obviously I'll need rotors, which size are used with these? E-brake cable, proportioning valve. Do I need an adapter plate, if so which one? What else?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear disk swap
...and the brake stuff shown below. I can't remember, but I think he said the stuff came from a 89 or 90 Iroc-Z. I'm wondering what other parts I'll need to swap these into my 87 with drum brakes. Obviously I'll need rotors, which size are used with these? E-brake cable, proportioning valve. Do I need an adapter plate, if so which one? What else?
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Car: 1987 Camaro
Engine: 355
Re: Rear disk swap
So essentially, the only thing useful to me in the pic is the calipers? It's a pain to find info on this swap on the site, or I'm an idiot.
This link was pretty helpful too.
https://www.thirdgen.org/forums/brak...drum-rear.html
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Re: Rear disk swap
TTT
Car: 1987 Camaro
Engine: 355
Re: Rear disk swap
I thought the PBR's were decent calipers? Or are they just better than the 82-88 setup? I'm not too worried about the E-brake because my car is an automatic. I'd like to have rear disks, but it's not an "OMG! I need these right now!" upgrade y'know? I made my money back just selling the tail lights so if the PBR's are junk, not using them isn't that big of a deal.
Re: Rear disk swap
JamesC
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Re: Rear disk swap
Those are aluminum calipers. There is one part that is tough to find and you have to find it used since it is not made anymore, I think it is the cable for the ebrake housing... Someone else will chime in. The calipers can bring good money - meaning over $100 and I think close to $150 since they are aluminum and only made for 89.
Re: Rear disk swap
No, in 89 they used bigger disc too.... I cannot remember exactly what the part is since I have two 89 rear ends complete - it doesn't affect me but there is one part that is tough to find to convert the disc and calipers to work on other 9 bolts.... I don't know if they can even work on a 10 bolt. Search using term PBR rear caliper.
https://www.thirdgen.org/forums/sear...archid=5288831
Re: Rear disk swap
Most of the info required for the swap is provided in the link in post #2. PBR's with their larger rotors were used on 9-bolts in 89, in 10-bolts 90-92 (in thirdgens). The single difference is that the backing plates have a different bolt pattern. Backing plates, cables and cable brackets are available from the following site:
http://www.flynbye.com/
JamesC
JamesC
Car: 1987 Camaro
Engine: 355
Re: Rear disk swap
Sounds like a lot of "love them or hate them" opinions about them on this site! Thanks for the info. Regardless if I can do the swap or not, I'm not sure if my current rims will work with it. One of my neighbors has an 89 Iroc Z that he special ordered in 88. I think he got the 1LE package. Maybe I can see if he'll take it out of storage and let me see if my rims will fit on it. If not, the swap will have to wait until I can find an Iroc rim (I've got 3 out of 4 on my parts car.)
Re: Rear disk swap
JamesC
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: Rear disk swap
Assuming you have a 10 bolt you will need to either make or buy a drum to disc adapter plate. Check the Flynbye website posted above. Rotors are readily available. May need to use to later 93-97 style rotors to fit over the ends of the axle. The emergency brake cable is available through flynbye also. some auto parts stores used to be able to order it also.
Will they fit your wheels is a good question. What size wheels are you using? These will fit in 16" wheels without a problem. Should fit most 15" wheels. Some needed to grind off a little from the fins to clear their 15" wheels.
I have the later style 93-97 PBR calipers which do not have the same fins and they clear the 15" wheels I am going to use. My calipers are essentially the same as those except for the fins.
Car: 1987 Camaro
Engine: 355
Re: Rear disk swap
Yes - 10 bolt. I plan on buying the adapter from flynbye, once I check rim fitment. The rims are an aftermarket 15"
Re: Rear disk swap
TTT
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Rear disk swap
You dont need a 1LE prop valve. Just get a late thirdgen prop valve. You can adjust how much pressure goes to the rear brakes with a $0.25 spring from a hardware store.
Re: Rear disk swap
JamesC
Car: 1987 Camaro
Engine: 355
Re: Rear disk swap
Oh ok. So, since I'm not upgrading the fronts in the near future, which will work correctly for now then? Or would I be better off getting an adjustable one?
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Rear disk swap
Hey, I know there's a ton of posts on rear drum to disk swaps, I can't seem to find what I need though.... and the brake stuff shown below. I can't remember, but I think he said the stuff came from a 89 or 90 Iroc-Z. I'm wondering what other parts I'll need to swap these into my 87 with drum brakes. Obviously I'll need rotors, which size are used with these? E-brake cable, proportioning valve. Do I need an adapter plate, if so which one? What else?
BTW if you do not plan to use the used disc backing plates in your pic, I would be glad to buy them from you. I have been loking for a set of 10 bolt backing plates for a while.
Car: 91 Trans am
Car: 1992 Camaro RS
Re: Rear disk swap
Regardless, as you know, the prop valves in these cars really dont do very much. Fronts always get 100 percent of the pressure, and the spring just moderates what fraction of that pressure goes to the rears also.
Car: 1991 Firebird Formula
Transmission: 700R4 to WC T5 swap
Axle/Gears: 2.73 drum to 3.73 PBR swap
Re: Rear disk swap
I'll take $100-150 for my aluminum calipers. They came off a rear end I bought used.
They aren't hard to find. I found remanufactured in stock all day from Napa, Advance, Auto Zone, etc...
Good news is they help keep these in circulation by charging high core prices. I bought 2 reman. PBR's from NAPA for $85/ea. with an $85/ea. core charge.
Am I returning my old ones...heck yeah!
Maybe hard to find already on a car, but not hard to find replacement if yours go bad or to buy outright.
