welding caliper brackets
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I turned down the drum axles in a lathe, and I've got my caliper brackets. I was thinking of cenering them on the correct spot and just welding them to the drum flange, rather than drilling and bolting them.
What do you folks think?
-- Joe
-- Joe
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 87' IROC
Re: welding caliper brackets
I think if done well, there is nothing wrong with your plan. Of course it will remove a bit a flexibility in case you want to change again in the future. And you need to keep heat out of everything so it does not warp. You really need the caliper to be parallel with the rotor. Weld very slowly and maybe keep everything covered in wet rags.
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
dbrochard
Sep 25, 2015 04:56 PM
