Line lock is holding front and rear brakes....
Old Sep 22, 2012 | 11:35 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Just wondering if this is normal or if there is anything I can do about it. I only have the front brake line going into the solenoid, but when I activate the solenoid and let go of the brake, the brake pedal doesn't move up. I'm guessing because the fluid in the front brakes isn't moving anywhere, the master gets stuck where it is. I have Wilwood 4 piston rear calipers and this makes it harder to do a burnout than it should be. I'm wondering if I'd even be able to once I get slicks on.
Old Sep 23, 2012 | 09:39 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Line lock is holding front and rear brakes....
did you put it before or after the prop valve?
Old Sep 24, 2012 | 06:06 AM
built91Z28's Avatar
I'm not running a prop valve.
Old Sep 24, 2012 | 08:31 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Thats wierd.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
