Bigger rims Better Brakes Help!
Old Nov 11, 2012 | 07:49 PM
salfirebird92's Avatar
Car: 92 Firebird Formula
Engine: 5.0 V8
So here is my question guys I have bigger rims on my 92 firebird 22" I know there big. I was told to upgrade brakes if so i seen kits from $400-1000, can I just put better rotor or brake pads without changing the calipers or buying something that expensive. or can I buy bigger rotors without changing the brake system.
Old Nov 11, 2012 | 08:39 PM
Engine: 5.0 V8
Re: Bigger rims Better Brakes Help!
Anyone?
Old Nov 11, 2012 | 08:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by salfirebird92
...or can I buy bigger rotors without changing the brake system.
Unless you upgrade to larger rotors, the OE system will look pitiful under 22" rims. The only way to go larger is to modify the spindle in front and remove the axle in the rear. As an example, check out the 1LE conversion:
http://web.archive.org/web/200605221.../1LEbrake.html
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Nov 11, 2012 | 09:06 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
There was a very recent discussion around here about upgrading braking systems, just a few days ago, that had a lot of good info. I don't remember the thread but it shouldn't be buried too deep in the pile.
Old Nov 11, 2012 | 09:22 PM
Engine: 5.0 V8
Thanks guys!
Frozer!!!
Jan 19, 2024 04:55 PM
Warlocksirix
Sep 3, 2015 12:26 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
