Combination Valve identity??
Old Jan 6, 2013 | 12:57 AM
Angelduran5858's Avatar
Car: 87 Camaro Z28
Axle/Gears: 4th Gen 3.42
I pulled this out of a 88 camaro with all wheels disc brakes can this be used to upgrade my 87 camaro's rear drum brakes to disc?? i did a but found nothing on this type of valve
http://i1288.photobucket.com/albums/...ps8fccf151.jpg
Old Jan 6, 2013 | 02:54 AM
tpi88camaro's Avatar
Car: 1980 Regal
Engine: 383 Superram
Axle/Gears: 12 bolt w/ 3.31 posi
Re: Combination Valve identity??
That is actually a valve that is used in the '85 and older cars. I am most certain someone replaced the original with that one. No way to know if it was from a 4 disk car or not. The function of both designs is the same so if it is from a 4 disk car it will work for you. Check this thread out. It talks about both design combo valves.
https://www.thirdgen.org/forums/brak...e-upgrade.html
Old Jan 6, 2013 | 06:29 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
That older valve along with the new and info about them can be found in the following FAQ:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Jan 6, 2013 | 11:18 AM
Car: 87 Camaro Z28
Thank You Made things a lot easier
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
okfoz
Sep 22, 2015 03:37 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
FormulasOnly
Sep 10, 2015 09:07 PM
