brake caliper - right or left?
I bought a 1984 trans am, and I am replacing the brake pads, calipers, and brake lines (goodridge stainless steel). The front calipers differ (right and left). When I pulled the wheel for the driver side, the installed caliper has the bleed valve on top and the brake line input on the bottom. Is that correct, or should it be the other way? Here are two photos from brake upgrade write-ups that are conflicting.
brake line input on top:
brake line input on bottom:
Engine: 4++,350 & 305 CIs
Re: brake caliper - right or left?
Brake line always feeds the bottom and pushes air out of the top.
Im sure if you look at yours it goes in the bottom also.
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
