locked brake
Old Feb 25, 2013 | 07:23 PM
iroczjoe's Avatar
Car: 1987 iroc z
Engine: 305 tpi for now
Axle/Gears: 3:24
locked brake
87 iroc. replaced both front rotors, bearings and pads. make a long story short the drivers side is stickin, i drove it 10 feet and realised it was sticking, when i stopped, i saw a little smoke. what is causing it to stick, i guess the caliper piston isn't returning but why? it was fine before. it got dark on me b4 i got to pull the wheel off and check it.
Old Feb 25, 2013 | 07:52 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: locked brake
When it sticks, open the bleeder and see if it unlocks, If not see if the slide pins move freely. If that checks good the piston in the caliper must be sticking. If the wheel unlocks when you open the bleeder something is holding pressure, likely the brake hose.
Old Feb 25, 2013 | 08:02 PM
iroczjoe's Avatar
Car: 1987 iroc z
Axle/Gears: 3:24
Re: locked brake
k thanks ill check that and the pin. reman caliper is only 13.99 at auto zone if i need it but doubt i wil thanks for the qick response
Old Feb 25, 2013 | 08:43 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: locked brake
The brake hoses often break down internally and act as a check valves. If the hoses have never been replaced, they're 25+ years old. One way or another, age is something to consider.
JamesC
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
