factory upgraded brake conversion
Old Mar 9, 2013 | 12:11 PM
walkthelin3's Avatar
Car: 1987 camaro,88 firebird
Engine: 2.8 v6,5.0 tpi
Transmission: manual
Axle/Gears: 3.47
a guy parting a car locally has the performance brake option on his rear end.. i have the stock disc option on mine. i was wondering, do i need just the bracket to make those calipers fit? i am of understanding that the rotors and pads are different so im excluding those from the question.
Old Mar 9, 2013 | 05:36 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Re: factory upgraded brake conversion
pbr's? aluminum, 89-97 style?
Old Mar 9, 2013 | 06:35 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I assume you're talking about the 89-92 PBR's.
Yes, you need the backing plates (along with all the other components, to include the combination valve).
Here's the how-to:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Mar 9, 2013 | 09:39 PM
Axle/Gears: 3.47
They are fron an 89 gta disc brake rear. The calipers look like this http://m.advanceautoparts.com/mt/sho...461%7CL3*15684
Idk which is pbr's and stuff like that.. Im a noob to this subject.. Is it worth upgrading? The guy wants 150 for the brackets and calipers
Old Mar 10, 2013 | 06:50 AM
JamesC's Avatar
Those are PBR's.
The set-up would be from a 9-bolt in 89, so if you have a 10-bolt, the backing plates won't fit (though the correct plates can be purchased). If your car is equipped with drums, you'll need to modify the axle flanges or buy a hassle-free kit from the following site:
http://www.flynbye.com/
The upgrade is worthwhile.
You'll have to pull the axles:
https://www.thirdgen.org/forums/tran...ling-axles.htm
JamesC
Old Mar 10, 2013 | 07:21 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
This is how they look on the axle.
Attached Thumbnails factory upgraded brake conversion-pbr-rear-brakes-1989   factory upgraded brake conversion-pbr-rear-brakes-1989
Old Mar 10, 2013 | 10:56 AM
Axle/Gears: 3.47
Yeah that is without a doubt them, i have a 9 bolt disc rear.just not performance
Vintageracer
Jan 10, 2020 05:33 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
lt1z350
Aug 28, 2015 05:57 AM
stalkier
Aug 13, 2015 12:59 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
