help with brake problem
Old Mar 29, 2013 | 11:15 PM
GreenieG's Avatar
Car: 1985 IROC-Z
Transmission: T5 manual
hi there, my problem is that most of the time when i go to stop the brake pedal is already hard and it wont stop quickly, sometimes i pump the pedal a couple times then when i push the brake pedal i get a better response from the brakes. could this be a sign to finally replace my booster and master cylinder? in the last year i have replaced every caliper on my car and theres new brake pads all around and ive replaced more then half the brake lines recently. but even then my brakes have been getting worse and worse in regards to the pedal and not being able to stop quickly. any help would be greatly appreciated thank you!
Old Mar 29, 2013 | 11:16 PM
GreenieG's Avatar
Car: 1985 IROC-Z
Re: help with brake problem
i should add im 99.9 percent positive the booster and cylinder are the original ones.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
overdriv
Aug 20, 2015 03:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
