Brake Issues
Old May 31, 2013 | 01:34 AM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
Brake Issues
O.K...I was replacing the front brake hoses on 92 Camaro and the reservoir ran dry to the front discs. Rear (drums) is still full! Having let the sucker go dry, do I need to bleed the whole system again? What about the master cylinder? I bled both fronts but my light is still on and my pedal has no pressure. I know I should bleed following the correct procedure but given the rear reservoir was full and I just wanted to get the car moving again I just did the fronts. I assume I still have air in the system. I've never had these issue in the past so I'm not sure what to do next. Such a simple task can be such a pain sometimes!
Old May 31, 2013 | 10:19 AM
87350IROC's Avatar
Car: 87' IROC
Re: Brake Issues
Your mistake is letting the whole system drain out. You now likely have air in the master that will never bleed out on the car. You need to bench bleed the master cylinder, which involves removing it from the vehicle. Doing a quick search should yield instructions.
John
Old Jun 1, 2013 | 08:21 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: Brake Issues
You don't have to remove the master cylinder to bench bleed it. Just unhook the 2 lines and put on the adapters and hoses. Then you can just push on the brakes pedal to bleed the air out. Same effect as if it was removed and chucked in a vise using a screwdriver.
Old Jun 2, 2013 | 11:22 AM
87350IROC's Avatar
Car: 87' IROC
Re: Brake Issues
The master needs to be level. Installed in the car it points up significantly, trapping air at the top. Sure you can level it by fiddling around jacking up the rear of the car, but its a heck of a lot easier just to remove the two nuts and do it off car. Not to mention on the bench you can actually see if you are getting air.
Old Jun 2, 2013 | 01:50 PM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
Re: Brake Issues
Thanks for all the responses guys. Turns out nothing was wrong at all. Light went off and the brakes work great.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
dyeager535
Aug 28, 2015 08:10 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
