c6 upgrade....now having issues
Old Jun 2, 2013 | 03:42 PM
Method_z28's Avatar
Car: 92 camaro z28
Brakes were fine before I upgraded my rear end and did a c6 upgrade. I did have the rear out of the car for 2 months with the rear lines hanging there. I also put new Russell lines on. I gravity bled the rear and 2 man bled the front. Now my pedal is extremely spongy. I checked for leaks...didn't see any. So since I had the rear out do you think I'm gonna have to bench bleed the master again?
Old Jun 2, 2013 | 03:49 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Re: c6 upgrade....now having issues
Take a soda bottle and put 1/4 new brake fluid in it. Take a vac. home and make sure its submersed in it. Put the other side on the bleeder screw. Crack open the bleeder and sealf bleed all 4 brakes again.
Make sure you dont run the res. dry. Doing it this way you only need one person. The line will only suck fluid back in and no air. Ive never had a problem doing it this way.
Old Jun 2, 2013 | 05:28 PM
Method_z28's Avatar
Car: 92 camaro z28
So hose on the bleeder with the other end in a soda bottle full of brake fluid?
Old Jun 2, 2013 | 06:56 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
correct
Old Jun 2, 2013 | 07:34 PM
Method_z28's Avatar
Car: 92 camaro z28
But if the rear lines leaked completely out wouldn't I have to bench bleed the master again? Fluid was still in the resevoir for the fronts.
Old Jun 3, 2013 | 01:26 AM
87350IROC's Avatar
Car: 87' IROC
Yes, if it was fully drained you need to bench bleed the master.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
