E-brake help
Old Jul 16, 2013 | 03:10 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
E-brake help
I dropped in a posi disc rear from an 87 with the delco moraine calipers. I reused my e brake cables and one caliper from my previous rear. it was a 10 bolt disc rear that replaced the original drum rear. I have a 91 5 speed and the ebrake cable from the handle is non adjustable.
the calipers work and lock up.
when you pull the ebrake handle all the way up the springs compress and weights move. the actuator is not moving (at least enough) to hold the rotor. before switching rears the ebrake held.
will the rebuild kit sold by gm parts direct fix this? or do I need to switch out the ebrake handle cable with an adjustable one?
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
jawzforlife1
Apr 25, 2002 03:36 PM
The Dirty Bird!
Apr 1, 2002 02:36 PM
stuart69427
Feb 22, 2002 08:38 PM
88transam5.0
Dec 19, 2001 06:58 PM
