Prop valve. 91-92 all the same???
Old Jul 21, 2013 | 11:21 PM
irockid43's Avatar
Car: 86 IROC-Z
Engine: 355
I am I the middle of my rear axle swap on my 86 IROC, I am switching from drum rear brakes to discs. I have been trying to research which proportioning valve I need to get the proper pressure to the rear brakes. I was looking for a disc/disc Camaro at the junk yard today but had no luck. I did find a disc/drum 1991 Camaro though. I took they valve. I've read on a few posts that the 91-92 valves are all the same. Is this true?? Does anyone have any info on this? Any replies would be great! Thanks a lot!!
Old Jul 22, 2013 | 06:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Prop valve. 91-92 all the same???
You need a disc/disc valve from, say, 85-88. The newer valves won't fit the thread pitch of your 86.
JamesC
Old Jul 22, 2013 | 11:10 AM
irockid43's Avatar
Car: 86 IROC-Z
Engine: 355
There sure are a lot of varying opinions on this. Other threads say that 82-83 valves are the only different threads. Any links or anything with definitive info?
Old Jul 22, 2013 | 11:21 AM
JamesC's Avatar
The early valves, 82-84 or so, are considerably different than later valves: They're iron, they have SAE threads and the lines are connected differently than the later valves. The 85 to early 89 metric valves are alum and look nothing like the earlier iron ones. The tube nut threads on these are M1.0. Late 89 to 92 have M1.5 tube nut threads.
More info in the following link (scroll down a bit):
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Jul 22, 2013 | 02:53 PM
irockid43's Avatar
Car: 86 IROC-Z
Engine: 355
Good link, I should have found that! I really appreciate it! Lots of good info!!
Old Jul 23, 2013 | 08:37 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
i have an 86 prop valve from a disc rear car
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
db057
Jan 10, 2020 08:55 PM
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
NZKnight
Oct 15, 2015 02:47 PM
