where can i get the e-brake y-point tensioner?
Old May 31, 2013 | 09:53 AM
whitecomet's Avatar
Car: 1987 Pontiac Firebird formula 350
Engine: sbc 355 tpi
Axle/Gears: 3.27 posi 9 bolt b/w
I have both left and right rear e-brake cables and the front center one but i dont have the part that connets all three together. does anyone know whats its called or where to get one?
Old May 31, 2013 | 11:02 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: where can i get the e-brake y-point tensioner?
Are You Referring To P.N. 6 In The Drawing,If So It's Called An Equalizer.
Old Jun 1, 2013 | 05:06 PM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
is there a schematic for the 91'-92' cars like this available somewhere???
Old Jun 4, 2013 | 04:17 PM
Pocket's Avatar
Car: 91 Trans Am
Junkyard
Beware there are two different types, ones like the diagram have a threaded portion of the cable going to the handle and can be adjusted as needed. Others like drum brake cars Ive seen use a fixed crimp on the cable so no adjustment can be made
Old Jun 4, 2013 | 04:55 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Seems like it would be a good idea to upgrade to the adjustable setup if he has everything apart. Grab the equalizer and the cable from the donor. Can this be done?
Old Jul 22, 2013 | 04:33 PM
whitecomet's Avatar
Engine: sbc 355 tpi
got the equalizer from pull n pay installed it an works perfect got 2 (different) e-brake cables just to be sure
Old Jul 22, 2013 | 05:38 PM
sheltonw3's Avatar
Engine: Classified
So if i get the "Y"-point tentioner, would I need to swap out the other two cables to the rear brakes as well to have this installed on a 91'?...and can it be installed on a 91' since General Monkey changed it it to a straight cable only?
Old Jul 23, 2013 | 08:34 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
yes and no. it depends. let me explain.
i have a 91 that was converted from drum to disc. (9 bolt disc from an 87) i used the disc brake cables, not the drum cables. i have to switch the equalizer out from a non adjustable(91)to an adjustable (87). HOWEVER...the mounting point to the brake handle for the disc equalizer(87) is different than the drum equalizer (91). the disc equalizer will not mount to the 91 brake handle. therefore i have to switch to the 87brake handle. the attachment on the disc is held in by a pin and the drum equalizer is not.
Old Jul 23, 2013 | 09:14 PM
sheltonw3's Avatar
Engine: Classified
So I would have to switch the rears from drums to disc and get a older style (1987) brake handle and everything else to make it all work?
Old Jul 23, 2013 | 09:38 PM
tonys91rs's Avatar
Car: 91 Camaro RS
to make it all work correctly, yes.
Old Jul 24, 2013 | 10:34 AM
gt4373's Avatar
Here's The 91-92 Diagram If It Will Help Any.
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
anesthes
Sep 30, 2015 07:48 AM
lakeffect2
Sep 7, 2015 03:52 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
