Two or three piece cable?
Old Aug 9, 2013 | 05:38 AM
Humph7ey's Avatar
Car: '82 Camaro '48 Pontiac Streamliner
Engine: 305ci (SUJ) Holley1850-3
Transmission: TM350
Axle/Gears: Stock
On my '82 rear disc e brake setup I ordered the 3 piece cable set as that was what was there with the so called equaliser (centre and two cable holes). The two back cables seem too long and don't equalise. I am wondering if it should have the single cable instead with the sliding equaliser.
At the moment I cant get the e brake to work evenly without damaging my wrist.
Is there a way to make a hydraulic e brake? Any ideas would be welcome.
Old Aug 11, 2013 | 11:18 AM
Humph7ey's Avatar
Transmission: TM350
Axle/Gears: Stock
Re: Two or three piece cable?
I finally fixed the e brake. All it needed was a 1mm shim behind the left outer pad. The trouble was that the lever was moving too far and only operating 2/3 which is way past right angles. With the shim in place the brake comes on 1/2" from the backstop. New pads might have fixed it but they are not worn out yet.
Has anyone had the piston apart? There must be some sort of sprag clutch in there.
wigmobile
Feb 26, 2025 02:56 PM
L0tuS
Oct 4, 2015 08:07 AM
gta892000
Sep 16, 2015 12:37 AM
corey8084
Brakes
Sep 15, 2015 08:14 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
