Caliper won't bleed
Old Aug 18, 2013 | 08:50 PM
shiftngo's Avatar
Car: 1987 IROC
Caliper won't bleed
Gents, the driver side front caliper on my '87 IROC locked up on me and I replaced it with a caliper off of an '89 RS. The problem is that I cannot bleed it. When I pulled the old caliper off, no fluid. I put the other on and had my girlfriend pump and hold. When I loosed the bleeder valve, nothing came out, no air no fluid, nothing. All brakes work fine except that one caliper. I even took the line loose from the caliper and pumped the brakes and nothing came out. I'm quite confused..
Old Aug 19, 2013 | 07:21 PM
toomany's Avatar
Re: Caliper won't bleed
Sounds like you have a collapsed line or hose on that caliper. Try loosening the hose where it connects to the metal line and see if there is fluid there.
Old Aug 19, 2013 | 08:53 PM
shiftngo's Avatar
Car: 1987 IROC
Thanks man, that makes sense. I'll give it a try.
Old Aug 19, 2013 | 09:24 PM
Eddie1986z28's Avatar
Car: 1986 Iroc Z-28
Engine: 1972 350 4V
Transmission: 1983 T5
Axle/Gears: Stock 2.73
good idea
Old Aug 22, 2013 | 10:23 PM
shiftngo's Avatar
Car: 1987 IROC
you nailed it toomany. I appreciate your help
Bubbajones_ya
Oct 25, 2015 08:01 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Luigytico09
Oct 1, 2015 08:46 AM
the_hamturdler
Sep 30, 2015 12:50 PM
