New Brake problem*
Old Oct 28, 2013 | 02:54 AM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
New Brake problem*
Over the past summer I went through hell to get almost everything fixed and now I got my rear right wheel leaking brake fluid, now mid you the brakes were bled and the prop valve and M.S. were replaced, the car stops perfect, but is it possible that the mechanic that bled and fixed my rear brakes might have simply failed to tighten up the right rear brake valve line while bleeding it?...I can clearly see some kind of fluid coming out of the drum, but nowhere else.
Thanks in advance!
Old Oct 28, 2013 | 07:05 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: New Brake problem*
That would be great if the bleeder just needed to be tightened. Usually this is an indication of a leaking wheel cylinder. You will have to get a closer look and find were the fluid is coming from.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
