ls1 front brake line question
Car: 88 Trans Am GTA
Axle/Gears: 12 bolt 3.73
I was going through some parts and found a set of earls brake lines for an lt1. I was wondering if these will work on my ls front brake upgrade. I am going to be putting the front end back togather monday night and figured I would ask here before I compare them.
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: ls1 front brake line question
the third gen hoses will work. i don't know about lt1 hoses.
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Ive been using the 3rd gen hoses from day 1. The factory replacements are cheap (~$13.00 per side). So Im sure stainless braided lines for a thirdgen would work on the LS1 swap too. Ive considered up grading to a set, but if I do, Ill probably just go custom length and get things routed how Ide like them.
There was a reason I didnt use the 4th gen hoses when I did my swap. I had them in hand...so if they worked I would have used them. And it probably had to do with the way they were secured. The thirdgen hoses clip onto the strut and onto a bracket on the inner fender. Im guessing the 4th gen versions didnt fit well, so I didnt use them. Cant remember 100%.
J.
J.
sailtexas186548
Jan 19, 2016 12:21 PM
