1LE Brake Pad Replacement
Old Apr 10, 2014 | 12:55 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Anybody done this before?
Not sure what extra steps I need to separate the calipers from the rotors since the calipers sit inside the special carrier....or is it even an issue since I'm not doing anything with the rotors?
Old Apr 11, 2014 | 01:12 AM
87350IROC's Avatar
Car: 87' IROC
Re: 1LE Brake Pad Replacement
Piece of cake. You do not need to review the carrier. Remove the two bolts holding the caliper to the carrier. Slide caliper off of rotor. Pads can now be removed from the carrier.
New pads will be thicker and you probably won't be able to get the caliper over the new pads. Temporarily remove the brake fluid reservoir lid. Using a caliper piston compressor or a c-clamp, slowly compress the caliper pistons back into the caliper body. Put lid back on brake fluid reservoir. Slide caliper over new pads and re-tighten caliper to carrier bolts.
Make sure to bed in new pads with the method described by the pad manufacturer.
John
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
kyleb24
Aug 15, 2015 08:24 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
