What size nut - Brake hose to brake line?
Old May 18, 2014 | 07:02 PM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
I'm trying to replace my brake hoses. They're cracking and appear a bit damp from brake fluid... Not very safe.
It should be an easy job (I've replaced brake hoses on other vehicles) , but I can't seem to loosen the nut that ties the brake line to the brake hose on my GTA.
A 10mm wrench is too small. It won't fit on the nut. A 12mm wrench kind of fits, but not well. It doesn't fit snugly and as a result, I can't put much force on it at all because it will just slip over the corners of the nut.
I dug up my SAE wrenches and a 7/16 wrench is too small and the next size up that I have is a 1/2 inch. It fits even looser than the 12mm wrench.
Below is a picture of the nut I'm talking about.....
Old May 18, 2014 | 08:15 PM
JonM's Avatar
Re: What size nut - Brake hose to brake line?
those flare nuts are typically 5/16 or 3/8 or 8mm or 10mm
im not sure what the oem size is.
Old May 19, 2014 | 08:01 AM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Thanks, but none of those wrenches will fit properly.. They're all too small.
I'm guessing that the ideal wrench would be 10.5mm or perhaps 15/32 inch... But locally those are hard sizes to find.
Sigh.. Maybe I'll have to break out the vice grips
Old May 19, 2014 | 10:31 AM
JonM's Avatar
My guess and im far from an expert is it got replaced sometime in the past. I would suggest when you redo the line use a part that fits a common size. If you bugger it up getting off just use a new one thats inline with your toolset.
Old May 19, 2014 | 12:53 PM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
OK, thanks Jon.. I think that's what I'll be doing.
Old May 19, 2014 | 04:18 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Just Recently Replaced Mine,It's 12MM.
Old May 20, 2014 | 12:26 PM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
OK.. Obviously your 12mm wrench fits.. I guess my nut has been damaged somehow.. Perhaps someone else rounded the threads and that's why my 12mm wrench won't grip properly.
Thanks for posting that photo.
Old May 20, 2014 | 05:40 PM
Marc 85Z28's Avatar
You should be using a line wrench!!
Old May 20, 2014 | 07:17 PM
JonM's Avatar
i bought a brake line wrench for my 03 silverado z71 its exactly 12mm... only fits one nut and its a pain to use. took it back cuz my regular box wrenches work fine.
gta's nut looks corroded and rounded off which may be his issue
Old May 20, 2014 | 08:14 PM
Marc 85Z28's Avatar
Corroded and rounded... that's WHY you use a line wrench!!
Old May 20, 2014 | 09:26 PM
JonM's Avatar
yes but it may be too late for him. worth trying though.
but it does look like the lines werent cleaned of brake fluid when it was installed last.
it doesnt sound like he rounded them off or allowed them to become corroded.
Old May 25, 2014 | 09:13 PM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Just to follow up...
I managed to get the nuts off the left and right hand lines today and now have new brake hoses. The nut was wet because I coated it with penetrating oil the day before I took the photo. (I usually do that with nuts and bolts that haven't been off for many years).
I wound up making a line wrench using a thin cutting wheel on my die grinder. It worked great!
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Eric-86sc
Apr 3, 2016 03:52 PM
toronto formula
Nov 10, 2015 06:17 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
knight72
Aug 10, 2015 09:32 PM
