strange brake problem
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
ever since i did my lsi brake conversion ive had a strange problem.sometimes when turn sharply in a parking lot my brake pedal will go to the floor.two pumps and its back to normal.i know im leaking fluid but i don't understand why it only does this once every couple of weeks.i thought it was the master cylinder so i installed a new one.no change.this happens only when i turn very sharply.any ideas?
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: strange brake problem
You know you have a leak, and you're driving on public roads? Get it fixed before you run over a baby carriage.
If your master if low on fluid, a sharp turn will slosh the fluid and might cause it to suck air.
Car: check
Engine: check
Transmission: check
The caliper or mounting bracket is hitting something, this is pushing the pad/piston into the caliper.
RBob.
RBob.
red90IROCls1
Aug 25, 2015 06:56 AM
