rear calipers reset procedure?
Old Nov 29, 2014 | 10:57 AM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Hi all.
Just restoring an 84 TA and have just rebuilt the rear calipers with new seals.
Pistons are back in and at the bottom of their travel.
When I put the pads in, do I press the brake pedal first or operate the emergency brake first to get the pistons into position?
Sorry for basic question!! Manual not arrived from US yet, to here in the UK!!
Thanks.
Andy.
Old Nov 30, 2014 | 11:44 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: rear calipers reset procedure?
You'll need to bleed the brakes first so that will set it up as required.
Old Dec 3, 2014 | 01:44 PM
Car: 91 camaro rs
Thanks for reply.
Bleeding brakes done already.
What do you guys do after replacing the rear pads? Just press the brake pedal a few times to get the pistons in the right place or pull handbrake lever up a few times?
I am aware of the TSB for the early disc brakes setting up, but ..........
Andy.
Old Dec 3, 2014 | 06:07 PM
Camaro86IrocZ's Avatar
Car: '86 Iroc Z & '91 RS
Engine: 305 TPI & 305 Qjet - Future LC9
Now pull the handle often to keep them adjusted..
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
