Brake Warning Light on Dash
Old Nov 29, 2014 | 01:10 PM
Nervous2's Avatar
Car: 1985 TRANSAM
Brake Warning Light on Dash is on -
Parking Brake connector is disconnected and is currently not on.
Light Stays on
When I remove proportional valve switch connector- Light goes off.
No Leaks, master cylinder is full.
How to diagnose? Any Suggestions?
Old Nov 30, 2014 | 08:24 AM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
If master is full, no leaks present, and brakes are as they should be, replace the prop valve switch.
Old Dec 2, 2014 | 10:01 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
Re: Brake Warning Light on Dash
if you have all wheel disk brakes the ac delco part number is 172-2005 "GM original Brake Combination Valve"
Old Dec 3, 2014 | 03:47 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
You may also have an air pocket in your prop valve.
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
