Spindle prep
Old Dec 6, 2014 | 10:58 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Spindle prep
After my motor swap is done I will start on my LS brake swap. Has anyone prepped their spindles on the car? I have a cut off wheel for the ears and a healthy drill for the bolt holes.
The only reason I could for sure see needing to remove them would be for the drilling and I have a drill press.
Sent from my iPhone using IB AutoGroup
Old Dec 9, 2014 | 05:00 PM
87350IROC's Avatar
Car: 87' IROC
Re: Spindle prep
If you can figure out a way to drill and tap the holes straight, then it would be acceptable to do it on the car. For most it is just easier to do it off the car.
John
Old Dec 15, 2014 | 12:49 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
I got my friends setup he removed when he did his V brake swap. I will strip and prep those spindles.
I have a drill press but if I don't feel sure I will get the guys in the machine shop at work to get it done.
Brackets are in just waiting for my hubs
Old Dec 21, 2014 | 06:29 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: Spindle prep
I did mine on the car.I used locktite red.no problems so far.
Old Dec 21, 2014 | 07:41 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Re: Spindle prep
I did mine on car too. No issues here.
Old Aug 22, 2015 | 10:30 AM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Re: Spindle prep
What size thread is suggested? I've read some people go with 3/8" and some with 7/16". Figure you can't go wrong with bigger, but is it better to go 7/16-14 or 7/16-20? The factory 1LE stuff is M12x1.75 (course).
I dropped my spindles off the the machine shop to get modified and told them to tap 7/16-20, and after reading this, I'm considering calling them and changing if they havn't yet started. Since it's for the racecar, I can see needing to remove the bracket a handful of times.
"Coarse threads are commonly used in ... relatively low-strength materials such as cast iron ... coarse threads provide more resistance to stripping than fine or extra fine threads."
http://cuttingtoolschicago.com/metal...-fine-threads/
Sounds to me course thread in better in the spindles. Thoughts?
Old Aug 22, 2015 | 01:04 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Go to the big brake upgrade site, everything you need to know is there. That site is what I used and it gave all sizes and specs.
I will suggest if you decide to do the threading yourself get a starting tap and a bottom tap. The start tap is tapered and what it dosent thread at the bottom is where the bottom tap comes in and you will need that bottom area tapped.
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
Drone358
Sep 21, 2015 08:54 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
jdperformance
Sep 16, 2015 11:55 AM
rb85TA
26
Sep 14, 2015 10:29 PM
