hand brake light on after a collision
Old Dec 9, 2014 | 08:17 PM
pimprs's Avatar
Engine: 3.1
Axle/Gears: stock
Collision wasnt major but I did hit the brakes pretty hard ...fixed the damage and now sometimes when i start the car the hand brake light is on temp gauge is pegged past 260 and voltage gauge is at 10 after putting it in gear sometimes it goes away or takes a lil time sometimes everythings good after...when I put the handbrake it wont light up...brakes are all good also front and back have newish pads/shoes...thanks for anyhelp
Old Jan 27, 2015 | 04:39 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: hand brake light on after a collision
Sounds like some stuff got messed up. The brake light coming on, could be the sensor in the proportioning valve being bad. I have a slight leak somewhere in my brake system that causes that light to come on. Unplug the sensor, no light.
For the charging, that's something else.
Did you make sure your temperature sending unit is good and not mashed/grounded? Its only one wire that goes to the gauge.
Old Jan 27, 2015 | 04:44 PM
pimprs's Avatar
Engine: 3.1
Axle/Gears: stock
Ok dam...yup the gauge always worked but I guess I should try an recheck an make sure thanks for the advice!!!
Vintageracer
Jan 10, 2020 05:33 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
