Vacuum Pump
Old Dec 19, 2014 | 05:56 PM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
Vacuum Pump
Is it worth the money thinking about a ele. vac. pump for my brakes do they make a lot of noise? an do they run constantly. Thanks.
Old Dec 19, 2014 | 06:33 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: Vacuum Pump
I am still building my engine, but I am going to buy a GM Aux Brake Booster vacuum pump on eBay (way cheaper than any kit you'll find online) and then buy this switch http://www.summitracing.com/parts/ssb-28146sw (and it's important that the switch control a relay and the relay control the pump) and you'll need a check valve and a T-fitting if you're going to use engine vacuum and just supplement it with the electric pump. I don't think they're loud, with the switch, you'll only run it when the vacuum needs to be increased so it won't be heard with the engine running.
Old Jan 29, 2015 | 12:52 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Re: Vacuum Pump
I have this on my car. You can hear it at idle a little(my car isn't very quiet either), but not much when your driving. It doesn't run constantly but frequently. Brake a couple times and it'll run for a couple seconds.
Old Jan 29, 2015 | 06:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Vacuum Pump
i bought one off ebay from a parted out earth mover, cheap and works very well in my gf's 78. Sourced an adjustable switch online too to control when its on and off. They run every now and again depending on brake useage.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
TreDeClaw
Aug 14, 2015 06:58 PM
