rear disc swap question....
Old Jan 12, 2015 | 03:34 AM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
I'll be buying a strange s60 rear here soon and they come standard with lt1 style backing plates for the PBR caliper swap, my factory 10 bolt was a drum brake unit. My question is can i use the same ebrake cables on the car(drum brake) for the pbr calipers? I know i need to get a disc/disc prop valve....car is an '86 with the adjustable tunnel mount ebrake setup.
Old Jan 12, 2015 | 06:19 AM
Re: rear disc swap question....
The front cable (back to the "equalizer" thing), yes; the rear ones, no.
You don't need to change the combo valve. The hydraulic requirements of the PBR system is similar enough to drums that in fact, the factory used the same valve in most years.
My 83 didn't need a change when I swapped PBRs into it.
Old Jan 12, 2015 | 06:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
For best brake performance, I'd use the appropriate valve. IIRC, GM made valves for disc/drum, disc/disc (Delco-Moraine) and disc/disc (PBR).
https://www.thirdgen.org/forums/brak...-question.html
JamesC
Old Jan 12, 2015 | 05:42 PM
thanks for the info guys, i kinda figured that with the e-brake cables. I'll use the disc/drum prop valve initially and see how it works, if i feel like it could be better, ill get a disc/disc prop valve....just wont hurt to try the one thats already one the car now. Anyone has a part# or interchangeable rear ebrake cables for the pbr swap with the tunnel mounted ebrake setup??
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
