Master Cylinder
Old Jan 12, 2015 | 05:11 PM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
Master Cylinder
What wrong with this master cylinder for manual brakes?Autozone nm 1822 could someone tell me if its good or not ? 87 iroc.
Old Jan 13, 2015 | 06:55 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Master Cylinder
At 1-1/32" the bore is most likely too large. Dependent upon the caliper bore area a manual M/C is typically in the 7/8" - 15/16" bore range.
Need to start with the caliper bore area and work back to the M/C bore area.
RBob.
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
