combination valve question
Old Jan 1, 2010 | 09:30 PM
charlietransam's Avatar
Car: 1984 Trans am
Engine: V8
what will happen i was to drive with a disc/drum combo valve and i have a 4 wheel disc setup?
Old Jan 2, 2010 | 02:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: combination valve question
the rears wont work as well as they could
Old Jan 2, 2010 | 04:02 PM
blackroc68's Avatar
mine actually worked better!
Old Jan 2, 2010 | 05:25 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Perhaps the rear discs themselves work better than the drums. If so, they'd be better yet with the correct valve, IMO. The following from another post:
In searching I've found that 89-91 shows the same Cylinder, Brk Master GM 18014286. Earlier years show different masters for J50 and J65. GM, however, pretty much made them interchangeable (All have the 'quick take up' master):
https://www.thirdgen.org/forums/susp...fferences.html
There are different combination valves (if only one was needed, why would GM design valves for different applications?). For exampe:
Valve, Brk Combo (1989 2nd Des) (J50) (1990 [and also 91]) (J41, J42) GM 10136839
J41 - BRAKE SYSTEM, POWER, FRONT DISK, REAR DRUM, CAST IRON
J42 - BRAKE SYSTEM, POWER, FRONT DISK, REAR DRUM, ALUMINUM
Valve, Brk Combo (1989 1st Des) (J65, 1LE, Y82) GM 14089496
J65- BRAKE SYSTEM, POWER, FRONT & REAR DISK
1LE - PERFORMANCE PACKAGE, SHOWROOM STOCK RACING
Y82 - MERCHANDISED PACKAGE, FORMULA
Using the correct application seems to be the right approach to me, but I'm a bit **** in such matters.
JamesC
Old Jan 5, 2010 | 01:00 AM
Iroczracer's Avatar
Car: 1989 IROC Camaro
Engine: Stealth Ram 355
Transmission: WC T-5
Axle/Gears: Torsion 3.42 Posi
My 89 IROC had the J65 brake option, so I never had a problem when it was changed to a 93 rear disc setup..
Old Jan 8, 2010 | 06:38 AM
blackroc68's Avatar
The rears are actually worse with the ile valve ?
Cameeeero
Sep 18, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
cRoe4
Aug 7, 2015 08:46 PM
