88 GTA - Ultimate Stock setup for non-PBR rears?
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
After reading this thread: https://www.thirdgen.org/forums/brak...setup-aka.html
What is the best option for those of us with the iron rear calipers? I gather that the only reason the upgraded setup works like it does is due to better PBR rear calipers, right?
Thx.
Thx.
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
Re: 88 GTA - Ultimate Stock setup for non-PBR rears?
either lt1(89-97 camaro/firebird) or ls1(98-02) rear brakes is your cheapest upgrade, the ls1 brakes wont fit behind most 15" wheels though without extensive grinding on the calipers.
Car: 1989 GTA, 1985 T/A
Engine: L98, LG4
Transmission: Slush-o-matic 700R
Axle/Gears: stock and stock
LT1 calipers will fit on your 9 bolt with 9 bolt-specific brackets. You can find them used (maybe?), or get a new set from flynbye.com.
Eric-86sc
Apr 3, 2016 03:52 PM
Street Lethal
Aug 13, 2015 08:28 PM
