Will these brake hoses fit?
Old Feb 11, 2015 | 08:16 AM
Thomas Stahel's Avatar
I'm looking for high quality braided steel brake hoses. As I've read here the Russel ones made problems for some of you, I was looking for the Goodridge ones.
I've found these: http://www.rickscamaros.com/camaro-b...1984-1992.html
I have an '88 TBI Camaro, just a normal one, not an IROC or Z28, at least I don't think so. So I'm not sure whether these hoses will fit. Does anyone have experience?
Thanks,
Thomas
PS: Is it true that I'll have to lift the engine in order to replace the front brake pipes?
Old Feb 11, 2015 | 02:02 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Will these brake hoses fit?
If your car has front discs and rear drums, you're good to go
JamesC
Old Feb 11, 2015 | 02:09 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
You may need to lift the engine to replace the hardliners, not the flex lines.
Those flex lines listed will work for you so long as u have rear drums.
Old Feb 11, 2015 | 03:25 PM
Okay, thank you, I do have front discs and rear drums. I just was unsure because the "standard" model wasn't listed for '88 Camaros in the compatibility list.
And using these steel hoses instead of rubber ones... there's nothing to be aware of when installing them? The ends which connect to the calipers look quite different to the rubber ones...
Hm, I'd like to replace also the hardlines... so lifting the engine, is that something I can do in my parking lot with a normal jack? Will I need to dismount anything to be able to lift it?
Thanks,
Thomas
Old Feb 17, 2015 | 06:37 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
You cant properly lift the engine with a normal jack. You need a hoist or ithe kind of support from the top.
I was able to get the hardlines off my v6 car without raising the engine, but I've never tried on a v 8 car.
1992 Trans Am
May 10, 2023 07:19 PM
sailtexas186548
Jan 19, 2016 12:21 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
1985chevydude
Aug 20, 2015 12:29 AM
