brake question
Old Mar 28, 2015 | 09:48 PM
lilpiston8's Avatar
Car: 85 iroc
Engine: 388 procharged
Transmission: 4l80
Axle/Gears: moser 9 inch / 3.40 gear
brake question
So I upgraded my setup to a full manual wilwood pedal and dual master setup. pedal is a 7-1 ratio. front master is 1 inch bore, rear is 3/4 bore. no prop valve. All lines go directly from the master to the calipers. have a BEAR kit on the rear. new lines and new stock calipers on the front. All lines are bled perfectly. so here is my problem pedal is hard and if i smash on the pedal at idle it just drives right through the brakes. car is impossible to stop. swapped the masters around and still the same. Any ideas?
Old Mar 30, 2015 | 01:14 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: brake question
does the pedal assembly have a brake bias adjustment screw on it? if so, you might need to adjust that to give you more pressure to the front brakes- you can get a **** that hooks up to it that you can mount to the dash that is the exact same thing that the NASCAR Cup guys use to adjust their brake bias on the fly.
other than that, i don't know what to say.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
