looking to do a break upgrade
Old Apr 8, 2015 | 02:47 PM
thorpe991's Avatar
Car: 1987 irocz
Engine: 5.0 305 tpi
Transmission: stock auto
Axle/Gears: stock not sure the ratio
So i am doing a motor swap/rebuild and into a better body and whule doing it i plan on putting in a few motor upgrades ie cam/intake/exhaust i know i dont need to upgrade the breaks as i wont be adding much hp but i would like to.
I looked at the first post in the break fourm and didnt see what i was looking for. I am wondering if i could pull the spindles and hub assembly and calipers off a 4th gen and bolt on to my 3rd gen struts and a arm/balljoint and would the cailper work with the stock 3rd gen break line.
I have 16" iroc rims so i think they will clear still
Old Apr 10, 2015 | 04:55 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: looking to do a break upgrade
no, you can't just unbolt anything from the front of a 4th gen and bolt it into a 3rd gen... well, i guess the lugnuts will swap over... but that's about it for major front suspension pieces..
also, it's spelled "b-r-a-k-e-s"..
Old Apr 12, 2015 | 11:52 AM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
You can use caliper and pads etc and rotors
You need to modify stock spindle quick search can find what's needed to do
You need to buy a machines hub with longer wheel stud and or do it yourself if you have the ability
Bracket for the brakes you want to run
You can buy hubs and bracket from bigbrakeupgrade you can then modify spindle your self and or buy them pre modified
But modified spindle and machined hub , bracket and your 4th gen calipers hardware and rotors
You love the upgrade and confident when stopping
Old Apr 12, 2015 | 09:09 PM
Nighthawkf-117's Avatar
Car: 91' Camaro RS
Engine: 305 TBI V8
Transmission: 700/R4
Axle/Gears: Stock
This is commonly referred to as the LS1 brake conversion.
Thread here,
https://www.thirdgen.org/forums/faq-...s1-brakes.html
And a complete guide here, this is where i learned when i did my conversion,
http://lukeskaff.com/?page_id=329
Linson
Oct 24, 2025 02:00 PM
apie2546
Oct 16, 2016 02:24 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
sjorgens
Oct 1, 2015 07:54 PM
mfp189
Sep 27, 2015 09:25 AM
