Upsizing early rear discs.
Old Apr 17, 2015 | 05:04 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
I know all the fuss about these calipers, but they're still available remanufactured, and I have all the stuff, so I'm putting these '84 Z28 rear disc brakes on the rear of an '83 RX-7 I'm building, it's new rear axle comes from a '94 S-Blazer 4x4. In this case, I got a couple of used Bronco II left shafts. Those are 5x4.5 rather than our 5x4.75, to match the front of the RX-7 ( This '83 has had the revised '86 RX-7 IFS swapped )
So then I got on Napa online to hunt brake rotors. I found some 10.51", or was it 10.53", that should have bolted right on. Correct lug pattern, correct center bore, correct hat height. But I saw some other rotors, identical except 11.3" diameter.
I ordered them, with the idea of modifying the Z28 brake backing plates, which bolt right on to the Blazer axle that came with drums, and which double as the caliper mounting brackets.
I just got done cutting them, so next will be pics of how I fit all this together, and inside the cheapest new cast aluminum 15" wheels I could find.
I see no reason why I couldn't copy this on the rear of my '86 Camaro, or my '87 S-10 for that matter. Stay tuned for bigger brakes on the cheap.
Old Apr 20, 2015 | 11:01 AM
cosmick's Avatar
Re: Upsizing early rear discs.
Getting the rear brakes figured out, red shows where I cut to accommodate the larger diameter rotors, welding will be required.
Old Apr 30, 2015 | 08:47 AM
cosmick's Avatar
Waiting on parts to arrive.
Old May 8, 2015 | 02:49 PM
cosmick's Avatar
So here it is: For about the cost of replacing the 10.5" rotors, it now has 11.3" rotors, no need to spend hundreds. Just a cutting disc and a grinding disc for my angle grinder, $1.43 of spare steel, a few rods for my stick welder, and a little electricity, it looks better, resists fade better, and stops shorter when loaded.
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Eric-86sc
Apr 3, 2016 03:52 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
E Rod
Aug 28, 2015 05:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
