Flex lines on rear axle
Car: 1990 Trans Am
Axle/Gears: Stock
Just a quick question:
Do those hard brake lines on the rear axle going left and right have a special name?
I don't mean the rubber hose.
Same goes for those ribbed lines coming after the prop valve below the master cylinder.
They're probably ribbed for more rigidity, right?
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Flex lines on rear axle
the "ribs" are actually a guard that protects the line from damage due to rocks and what not... it just slips over the lines after they are bent bot before the last end is flared..
you can buy it at parts stores.
ambainb
Apr 25, 2016 09:21 PM
mhatfield 14
Oct 24, 2015 07:48 AM
AkDrifted
Aug 17, 2015 07:45 PM
