SPEED BLEEDERS
Old May 9, 2015 | 08:13 PM
gt4373's Avatar
Transmission: 5-Speed Manual
SPEED BLEEDERS
Anyone Have Speed Bleeders Installed,And Do They Work Without Leaking Or Letting Air Back In The Line.
Old May 10, 2015 | 07:55 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: SPEED BLEEDERS
I've used them. No problem, but I'm not sure they're worth it.
Old May 10, 2015 | 11:40 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: SPEED BLEEDERS
I rounded a bleeder on a front caliper on my car, decided $11 to be able to bleed the brakes myself using pressure was better than having to get a helper (or using vaccum) and spending $4.
Glad I did. Dorman sells them now. The threads are coated with a sealant. So air back into the caliper should be minimal.
Old May 10, 2015 | 11:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: SPEED BLEEDERS
A while back a purchased some so-called speed bleeders. Nightmare. I finally resorted to "wife help."
JamesC
Old May 10, 2015 | 07:53 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Re: SPEED BLEEDERS
I use a vacuum bleeder to get the new fluid to the bleeder, then finish up with the "wife" method for the final bleed.
Elephantismo
Feb 13, 2019 12:51 AM
jrdturbo
Mar 31, 2016 02:58 PM
RedLeader289
Sep 23, 2015 06:50 AM
84redta
Sep 19, 2015 09:58 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
