replaced prop valve spring - now no brakes
Old May 16, 2015 | 01:49 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
I replaced the spring, bled the rear brakes and now the brake light on the dash is on and i have no rear brakes. did I miss something in this process?
Old May 17, 2015 | 01:57 PM
Prime's Avatar
Car: 91 Firebird Vert
Engine: LO3
Re: replaced prop valve spring - now no brakes
I bled all the brakes when I did mine, front and rear. I would guess there is air in the system.
Old May 18, 2015 | 12:06 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
when i was playing with the prop valve spring, i would take the rear wheels off and squeeze the calipers to push fluid back thru the system to the master cylinder.. this pushed the air out of the lines and into the reservoir and i never had to bleed it..
1988iroc350tpi
Aug 14, 2015 07:52 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
