Upgrading my front disc brakes
Car: 89 GTA
Engine: 5.7 TPI
Hello I was wondering about my front disc brakes.. It seems my 89 GTA Trans Am still has a single cast iron single piston caliper with an pretty small rotor. I had order a set of calipers and rotors that were performance, but clearly they don't match my current spindles. Now I have come to learn it was a 1LE performance package.
My question is do can I just swap out the current spindle for the new ones? Classic Industries has a complete conversion kit for the 1LE package http://www.classicindustries.com/pro...ts/md123b.html. Can I just bolt on these new spindles with the new brackets, rotors, brake line harware... and such? Or is there more I need to get?
Car: 91 G92 Z28
Axle/Gears: 342
Re: Upgrading my front disc brakes
You can modify/drill your spindles to fit the 1LE caliper brackets. So you'll need to source the brackets to go along with the calipers you bought. Or just get that package deal from classic.
If I were you I'd return those parts and do the LS1 conversion. It's cheaper and arguably better than the 1LE brakes. Try here: http://www.bigbrakeupgrade.com/ls1_complete.html
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Bryan that's the upgrade I did a couple years ago. Scott is the man. You will happy you did it. Huge difference at the right price.
Car: 1989 Trans Am GTA
Transmission: M28 T56
Also had a great experience with Scott.
I opted for the C5 Brake swap though. Well worth it, car stops so nice.
Car: 89 GTA
Engine: 5.7 TPI
One last question though. Will I need to change my master cylinder or the power booster for the new rotors? Or is it as simple as bolting on the new hardware?
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
I got the LS1 front disk upgrade from Scott at Bigbrakeupgrade too.
Very happy with the choice, it's the best option for the bucks and Scott is good to deal with.
Car: 89 GTA
Engine: 5.7 TPI
Wasn't what I was asking. I was asking if I need to change my master cylinder and brake booster because I am changing to these brakes. Or is it just a bolt on job.
Car: 1980 Regal
Engine: 383 Superram
Axle/Gears: 12 bolt w/ 3.31 posi
I'm guessing you have 4 wheel disc brakes on your '89 GTA??? If that's the case you should be good to go as most with 4 wheel discs don't change the master cylinder or prop valve unless afterwards they have a problem with the rear brakes locking up. But you won't know that until after you put the ls1's on. Every car is a little different than someone else's. Everyone has different expectations. Hope that helps.
Car: 89 GTA
Engine: 5.7 TPI
Car: 91 Firebird Formula
Engine: 5.7
I wouldn't hesitate to ask Scott your question. I have read a few threads concerning his products. It is my understanding that he is forthcoming and responsive. Seems like a standup guy.
I will be purchasing his products when the time comes.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
