Right Rear Caliper Moved On my 89 Iroc
Car: Camaro IROCZ28
Engine: 350 V8 5.7
Transmission: Auto-Shift kit
My Caliper moved while I was driving so I pulled over and realized that it was missing the bottom bolt. So I went ahead and bought a bolt tightened it. On my way home from work I did it again but was worse. This time the Caliper moved all the way to the bottom and got pulled out the brake hose. I want to get a new replacement for the rear disc brakes I can't find any for the rear specifically.
Anybody know where I could get some?
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: Right Rear Caliper Moved On my 89 Iroc
did you check? every major auto parts supplier internet and local has a caliper you can order for you 89 camaro
Car: 88GTA
Engine: 5.7TPI
Ordered mine from Advance Auto Parts. Showed up in 3 days.
Was the thru bolt not tight or what? Never heard of such a thing
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
An 89 with rear discs (J65) should be equipped with alum PBR's. Often called "performance" or 1LE calipers, they should be available from any parts store.
JamesC
JamesC
Car: 88GTA
Engine: 5.7TPI
Sorry, going blind. Thought it was an 88. Advance has them also;special order
Car: 1991 Pontiac Trans Am
If the caliper was ripped out of its mounting spot then in my opinion, something is seriously wrong back there. You need to take things apart and either get pictures for us or determine yourself what's wrong before just tossing another caliper on there. It's also likely you'll need more than just a caliper. Not to mention that they are bolted in to a bracket and if they've ripped through that, well, that's a mess.
Eric-86sc
Apr 3, 2016 03:52 PM
AkDrifted
Aug 17, 2015 07:45 PM
mustangman65_79
Aug 11, 2015 03:17 PM
