Brake hose issue
Old Jun 17, 2015 | 01:30 PM
t/aws61985's Avatar
Car: 85-6 TA 85 IROC 82-86 MSE 83 Pace
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
Brake hose issue
I recently upgraded my brake hoses with a 5 piece set from hawks. It came with 2 long hoses for the front, 1 hose for the center (the one on the rear axle),and 2 medium sized hoses for the rear calipers. I used all the hoses besides for one medium-sized rear caliper hose. I noticed that instead of a flex hose, on the right caliper, there is a hard line.
So the question is, what should I do with this 5th unused line? Would it be ok if I added it to the driver side rear caliper?
Old Jun 17, 2015 | 01:37 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Brake hose issue
Just keep it handy. Hard lines are better than rubber.
Old Jun 17, 2015 | 02:41 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
It sounds as if you purchased a kit for 89-92 cars, which were equipped with flex lines to both rear PBR calipers—for a total of five lines.
JamesC
Old Jun 17, 2015 | 02:51 PM
t/aws61985's Avatar
Engine: Slow ones
I bought the set for 85-88 cars with rear disc. They are Kevlar/ steel braided.
Old Jun 17, 2015 | 02:54 PM
JamesC's Avatar
That begs the question then of why the kit contained five hoses since only four are required. Interesting.
EDIT: Curious, I visited the website and found the following:
Brake Line Kit, StopFlex Braided Brake Lines 85-88 Camaro & Firebird, Front Disc & Rear Disc, Hi Performance Option (5 pc kit).
The issue, IIRC, is that for all practical purposes there were no cars, 85-88, that were equipped with the high performance option (i.e. 1LE). All J65 cars with Delco-Moraine iron calipers required four-piece lines. BTW, Hawks does offer the correct four-piece kit.
JamesC
Old Jun 17, 2015 | 08:38 PM
t/aws61985's Avatar
Engine: Slow ones
The 4 piece kit they offer is the Russel brand. The stop flex brand seems to be much better. Upon embarking, upon this plan to upgrade my brakes I didn't realize that my car only needed 4. I just figured I need 5 due to 1 per wheel and one center hose. I also bought slotted and drilled rotors, and new pads. This is my first time doing my brakes myself so this I all really new to me. Having alot of issues with the rear brakes.
Old Jun 18, 2015 | 12:21 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
personally, i'd cut and flare the hardline that goes to the one caliper and put the flex line in there. i can't see how that caliper can properly float with the hardline holding it in place.. this isn't the only vehicle that GM did this on, tho... there are actually some cars from the late 70's and early 80's that don't have flex lines on either of the rear calipers.
Old Jun 18, 2015 | 12:54 PM
t/aws61985's Avatar
Engine: Slow ones
I'm considering adding it too. But I don't want to mess up the system.
Old Jun 18, 2015 | 01:26 PM
JamesC's Avatar
I doubt that the time and effort will make a difference in brake performance. That being so, why bother? At any rate, good luck with whatever you choose.
JamesC
Old Jun 18, 2015 | 03:47 PM
novaderrik's Avatar
Car: 86 Camaro
JamesC
easier changing of brake pads would be one good reason to put the flex line in..
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
dyeager535
Aug 28, 2015 08:10 AM
