Wheels won't turn!
Old Jun 28, 2015 | 01:43 PM
Badluckbrian's Avatar
Wheels won't turn!
I finished up putting brakes on my 86 (rotors and pads) and took it for a test drive. When I got back my passenger side brakes were smoking and when we lifted it up you couldn't turn either of the wheels, we replaced one of the calipers and it still does it we've tried blessing them but it's no use, please help!
Old Jun 28, 2015 | 02:17 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Wheels won't turn!
Welcome to TGO, Badluck.
The flex hoses have probably failed internally and are acting as check valves keeping the brakes engaged. The hoses are, unless they've been replaced at some point, going on 30 years old.
JamesC
Old Jun 28, 2015 | 02:20 PM
mk1431's Avatar
Car: 89GTA Black, Black cloth
Engine: LB9 26,000 miles
Axle/Gears: 3.45 Australian 9 bolt
blessing them wont help try bleeding them something is holding pressure could be a flexline inner liner collaspsed or master cly cup valve stuck go up the brake lines and crack the connections until brakes release then problem is between there and calipers
Old Jun 28, 2015 | 04:04 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Old Jun 28, 2015 | 05:04 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
If it smoked long enough recheck the grease in the bearings.
Old Jun 29, 2015 | 02:13 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
if it's both wheels on one side of the car, then it's not a collapsed hose.. if it's the front and rear, then it's up by the master cylinder..
try loosening the bolts that hold the master cylinder to the booster: if it releases the pressure, then the brake pedal isn't fully releasing for some reason and it's time to crawl up under the dash and see what's happening... i had this happen on a 74 Monte Carlo i used to have, and it was caused by a plastic ring of some sort fall off inside the booster where the pushrod from the pedal goes thru the firewall, which didn't let the brake pedal fully retract.. i pulled the loose part out and it worked perfectly for the next 4 years that i owned the car..
Fronzizzle
Mar 18, 2019 08:29 PM
Derick15
Sep 17, 2016 05:28 PM
B_Dubya
Aug 26, 2015 05:09 PM
Fronzizzle
Aug 9, 2015 01:15 PM
BrianI
Aug 9, 2015 11:52 AM
