How to adjust parking brake?
Old Dec 30, 2015 | 10:30 PM
'91CamaroRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: 4 Speed Automatic
This car has sat for years,so the parking brake has become loose. I wanna know how to adjust the cables to tighten them. Where is the adjuster at?
I have an additional question that kinda goes hand-in-hand with this. The car has poor brake pedal breaking. I've tested everything for the pedal issue,and nothing has worked. My question is,can the loose parking break be somehow related to the poor brake pedal performance? I know it's not air,so please don't say that's all it is.
Old Dec 31, 2015 | 06:53 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: How to adjust parking brake?
If you want to test it, try this.
pull the handbrake, how high does the lever come up? Is it a lot?
does the car roll in neutral with the jamdbrake up?
pull the handbrake up only enough to barely engage the brake, then try the pedal, does it feel better or the same?
if its the same, then you still have another problem
if its much better, then the drums/brake need adjustment
Old Dec 31, 2015 | 06:54 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
The handbrake engages the rear brake shoes the same as the regular brakes, so if they are loose, all that extra slop will create a lot of excess pedal travel which will give the feel of poor braking
Old Jan 1, 2016 | 05:36 PM
Beeman's Avatar
Rear drum?Disc? Does the parking brake work? If the applying the parking brake improves pedal quality you have another problem. if drum then your shoes are out of adjustment, if disc then your calipers need replacing.
Old Apr 28, 2016 | 01:28 PM
Harlem Z28's Avatar
My parking brake handle keeps popping up, how can I adjust it? 1985 Z28 5 speed.
Old Apr 28, 2016 | 03:16 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The adjuster is above the drive shaft in the tunnel. Give it a visual. Are the cables connected at the brakes?
JamesC
Old Apr 28, 2016 | 03:17 PM
JamesC's Avatar
As I recall, the 91 should be self adjusting.
JamesC
Old Apr 28, 2016 | 03:22 PM
mjoekingz28's Avatar
Car: 2006 Chevrolet Cobalt
Engine: 2.2 DOHC Ecotec
Transmission: 4spd auto
The parking brake pulls a cable tight.
The brake pedal forces DOT3 through the wheel cylinder.
Old May 2, 2016 | 08:46 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
You haven't worked with the stock brakes then, what //\\ said is correct. Some of the rear brakes move the part that actually touches the shoe, so if the shoe is loose then the E-brake may not function properly.
ndndndnd
Dec 30, 2015 01:13 PM
'91CamaroRS
Brakes
Dec 14, 2015 01:07 PM
jorgeblancojr
Dec 11, 2015 11:33 PM
wolftamer389
Brakes
Dec 11, 2015 08:56 PM
fordspanker
Dec 2, 2015 10:03 AM
